billy Posted January 8, 2004 Report Share Posted January 8, 2004 I made this several years ago when I was a real newbie, but it still helps sometimes when the brain stops working :DHope it helps ! 8)The_E12_Resistor_Series.pdf Quote Link to comment Share on other sites More sharing options...
mixos Posted March 1, 2004 Report Share Posted March 1, 2004 If you are looking for labels to organize your resistors and be able to find them easy and fast you can print out the following sheet and cut each piece of label to attach it to your boxes. It inlcudes all the common resistor values at 5% tolerance. Quote Link to comment Share on other sites More sharing options...
Ldanielrosa Posted March 5, 2004 Report Share Posted March 5, 2004 Good morning Mixos. Either my groggy eyes deceive me or the colors aren't rendering correctly on my computer. Your entry for 100K looks like1G0. Also you showed 010 for 100R. You may want to put a "G" for the third band on the sub-10 ohm values. Quote Link to comment Share on other sites More sharing options...
mixos Posted March 12, 2004 Report Share Posted March 12, 2004 Thanks for the corrections Ldanielrosa. I already updated the above images. Quote Link to comment Share on other sites More sharing options...
Guest Yevgenip Posted March 26, 2004 Report Share Posted March 26, 2004 Thanks Man! You're Great!!! ;DI hope to become a Jr. Member myself one day, But how members are rated around here? ???Thanks for the Info. Quote Link to comment Share on other sites More sharing options...
mixos Posted March 26, 2004 Report Share Posted March 26, 2004 Members rated depending the messages they write.0-50 posts: Newbieover 50 posts: Jr. Memberover 100 posts: Full Memberover 250 posts: Sr. Memberover 500 posts: Electronics God Quote Link to comment Share on other sites More sharing options...
CRE Posted December 7, 2004 Report Share Posted December 7, 2004 Ok, I know this is an old thread but it seems the best place for my question instead of starting a new thread.... What's the proper color code for a 1 Ohm resistor? Black, Brown, Black or Brown, Black, Gold? Quote Link to comment Share on other sites More sharing options...
ante Posted December 7, 2004 Report Share Posted December 7, 2004 Hi CRE,They both work fine, here you can try different color codes: http://www.electrician.com/resist_calc/resist_calc.htm Quote Link to comment Share on other sites More sharing options...
CRE Posted December 7, 2004 Report Share Posted December 7, 2004 Thanks for the prompt reply Ante.Ok, so there isn't one that's "right" or "standard"? Has anyone here come across either or both? (I'm making a chart and labels for my organizer... ;) ) Quote Link to comment Share on other sites More sharing options...
ante Posted December 7, 2004 Report Share Posted December 7, 2004 Hi CRE,As far as I know they are correct since I have encountered them both on many occasions. Quote Link to comment Share on other sites More sharing options...
Dazza Posted December 7, 2004 Report Share Posted December 7, 2004 Thank you mixos,billy, I'm not over the hill, but I am not a spring chicken either ;D but man I've got a terrible memory, this will make finding that resistor much easier :D. So I will become an Electronics God when I reach 500 posts. Man that was easy to learn electronics 8) ;D, maybe it should say something different for me, for someone that asks for a lot of questions and for help, and still knows very little ;D ;D ;D. Quote Link to comment Share on other sites More sharing options...
CRE Posted December 8, 2004 Report Share Posted December 8, 2004 Thanks again Ante,Anyone know of any other values in the E12 (or even E24) range which has two valid codes? Quote Link to comment Share on other sites More sharing options...
