Jump to content
Electronics-Lab.com Community
Capacitor variety
Does anybody notice the variety of capacitor types that exist. I am sure there is a measurable difference, but it is subtle. Of course the value of the capacitors are different, given the same construction. My problem is my meter. It' doesn't measure low voltage AC very well. It's a radio shack autorange fit's in pocket.
Link to comment
Share on other sites
  • 4 weeks later...
Yes you can make a homemade capacitor which will obey the equations.
I have read this in a small 'LEARN ELECTRONICS' manual.
Take a alluminium foil and paper.
The alluminium foil should act like the plates and paper as the dielectric. Then roll them up into shape of a cylinder. Simple.
A more complex way you can make a multilayered capacitor.
For eg:-
Take 6 alluminium layers and 6 that of paper.
Stack them up alternately.
3 aluminium layers should form one plate and remaining 3 the other plate.
Roll it up.
You could make a container for the capacitor.
The capacitors you make are quite large in size compared to the same valued capacitors of ceramic or paper capacitors but they do sometimes work perfectly .
I myself tried this once successfully but got irritated by its size.
But its a good try!
Link to comment
I have a homemade inductor that I will use in a power supply circuit. It has a very high current rating, but it does not obey the equation very well. It is made with many strands of magnet wire, combined together, then wrapped around a transformer core. When I increase the frequency 10 fold, it should increase the resistance 10 fold, but it doesn't. I do, however, trust the high current possibilities. I have to wonder what the resonant frequency will be if I add the capacitor to it. The load would then be in parallel to the capacitor.
Link to comment
I do not know the value of capacitor(don't have a meter for it).But i had repalaced it in simple amplifier as coupling and worked very well in that case .
But when tried it in an oscillator and it worked just below good.
This was pretty long time ago(a year).
As for the size it was about 2 inch long and about 1/2 inch in diameter.
It must have had a poor tolerance level and hence must have not worked in the oscillator.
Link to comment
I was thinking about this in an audio type of set up. Car stereos need a large bypass capacitor on the 12 VDC power side to help deliver the good base response from the newer high power amplifiers. Usually a 1 farad capacitor is used. However, such large value capacitors are very expensive. If one could be made easy enough with aluminum foil plates and paper insulators but not require a trailer to carry it ;D, this would be a great alternative.
I can certainly see where a fuse would be necessary on this in case of a short in the home made device. Car batteries have a lot of current capability.
MP
Link to comment
I made the resistor.
Its fine.
Following things i found.
A HB pencil gives resistance of only 8-9 ohms.
A 2B pencil gives resistance of 11-12 ohms
An unknown pencil gave me resistance of 3.3 kiloohms.
All pencils(graphite rod) were 17 cms. in length(approx) and 2mm in diameter.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
