Jump to content
Electronics-Lab.com Community
Impedance matching
Kevin Weddle
I want to use a 50ohm cable. This gives you capacitance as well a inductance. Somehow the load impedance will affect the line impedance. If you say the load impedance is closer to a short, then the length of the cable should be chosen to be a series inductor capacitor at the resonant frequency. This is the 50ohm seen by the source. I want to make sure of this with the oscilloscope. A standing wave will appear as an offset of the signal. Am I right?
Link to comment
Share on other sites
  • 2 weeks later...
This will require the formula
wavelength = (.67)100x10E6 / frequency
What do you do with the wavelength? You also have to incorporate the load resistance. I would make the length some fraction of the wavelength. I would assume the load to be a short because it will be closer to a short. If you make the length the correct fraction of the wavelengh, you will get the line at it's resonant frequency. You don't want it to appear inductive or capacitive, but do you want it to be parallel resonant frequency or series resonant frequency? I think it should be series resonant frequency because a 50 ohm cable is closer to a short. Any suggestions about measuring the end result.
Link to comment
kevin, perhaps I am not understanding, but I thought you wanted to find the resistance of wire when knowing the thickness and length. If this is the case, there is a nice little calculator here at the link:
http://www.mogami-wire.co.jp/e/cad/wire-gauge.html
MP
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
