Jump to content
Electronics-Lab.com Community
C problem
I am using the Borland compiler and the examples don't seem to work. I make a call to a standard function in the correct header file and it says it doesn't exist. What could the problem be? I have had similar problems with serial communcations functions.
I have a theory as to why it does not work. I think my windowsXP does not support these functions. Could this be true?
Link to comment
Share on other sites
I quiried another post to find out that many functions aren't supported by the WindowsOS. However, my compiler is compatible with earlier Windows versions. I guess I just needed to read my CD to find out. But I cannot believe that my functions don't work just because it's WindowsXP. I posted in this forum because I believe that the basis for microcontrollers is the programming. I need at least to use functions that will interface with the microcontroller through the parallel and serial port.
Link to comment
due to sequrities and protection you might face problames with windows xp and windows NT.this problame will not occure with windows 98.or if you want to work with windows xp and windows NT then ask the qustion in on-line help by microsoft their engg. will show you the way....ok
Link to comment
  • 2 weeks later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
