Jump to content
Electronics-Lab.com Community
design and construction of intruder alarm with security light
there are (building wise ) two different types of dectecto, powered and un powered but both work the same.
A basic intruder alarm has
12V supply +bat backup
12v op for powered devices,
NC tamper loop
NC detector loop.
Alarm output.
***************A diagram will be up by monday 27th**************
Zone1 = triditionaly entry/exit = when dector is open a timer starts if the detector circuit is not closed the alarm triggers.
Tamper= all device have tamper conectors if a case is open or cable cut alarm sounds.
Zone2-n NC circuits= id dector circuits open, alarm rings.
If the circuit is wanted i will put a rush order on the design.
Link to comment
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
