gauri_22480 Posted December 10, 2004 Report Share Posted December 10, 2004 can I drive mosfet bridge (H bridge) using 555 timer ? how?I know ......we can give triggering pulses to mosfet using microprocessor......or using some IC .........but because of some problems I don't want to use microprocessor or any specific IC .......so do let me know is there any other method to give triggering pulses to mosfet bridge. Quote Link to comment Share on other sites More sharing options...
Kevin Weddle Posted December 10, 2004 Report Share Posted December 10, 2004 It might be of some use, but you can use the output of a gate and set an inductor to ground. This means that with the occurance of an input, like a switch from low to high, you get a pulse that goes low to high back to low. A simple one shot that does not require a pulse on the input. Just a single transition will work. Quote Link to comment Share on other sites More sharing options...
