Jump to content
Electronics-Lab.com Community
Beacon Finder Robot
For my college project i am building a robot that will drive towards an IR beacon, avoiding objects along the way. i already have ideas of how to do the most of it, but there is just one thing i don't know what to do about.
How can i make my robot 'know' when it has found the beacon... i can imagine it getting to it, but then just pushing it around in a much like carrot hanging in front of a donkey situation!! I want it to stop when it gets to the beacon. This has got to be relatively simple and cheap.. Any ideas?? I'm stumped. :(
Leigh
Link to comment
Share on other sites
You are joking surely??
anyway.. what i mean by beacon is a device that will send out infra-red light, with a fixed position... like placeing a torch on the floor, and then my robot going towards the light... My robot wil look for IR light, and go towards it.. but i need it to know when it is there rather that it just keep pushing it around, and dnt know how..
thanks for the help..
Link to comment
Guest Yevgenip
Sorry my English is not as good as yours... ;D
But as you say, Never Stop Learning!!!
What I really meant was: Do you have th option of actually Touching the Tourch with the robot?
Link to comment
The reed switch is a good idea, but how close will they need to be for it to work? maybe i could get a powerful magnet, but will it only work from one side of the beacon?
and no i dnt have to option of the bot making contact with the beacon, the object avoiding system will not allow the bot to hit anything (hopefully!)
thanks
Link to comment
Guest Yevgenip
Yeah, you can use the already existing system of IR tracking in you robot (I hope you have it) to measure the strength of the IR signal so when it reaches a certain high level, it will know that it reached its target.
Link to comment
One method commonly used is with an ultra sonic transducer which is used as a proximity detector. For a completely simple device, you can use a switch used the same as CNC equipment limit switches that detect when the table has reached the home position. Ther are lots of levels in between these two suggestions.
MP
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
