ECET0purdue Posted August 16, 2005 Report Share Posted August 16, 2005 just as the subject says.... ;D Quote Link to comment Share on other sites More sharing options...
audioguru Posted August 16, 2005 Report Share Posted August 16, 2005 I wouldn't re-use a cap without a label because you won't know its voltage rating.If it is defective and needs replacement then testing it will probably give a false reading. Quote Link to comment Share on other sites More sharing options...
ECET0purdue Posted August 16, 2005 Author Report Share Posted August 16, 2005 no there new... just i got some mixed up... some are blue with black line? i just was not sure if there was a decodeing system like there is for resistors? Quote Link to comment Share on other sites More sharing options...
MP Posted August 16, 2005 Report Share Posted August 16, 2005 There is a marking system for capacitors. I think someone posted a link to a site for this somewhere on the forum. You might find it with a search. If you can tell us the markings, one of the members here might be able to steer you in the right direction.MP Quote Link to comment Share on other sites More sharing options...
ECET0purdue Posted August 16, 2005 Author Report Share Posted August 16, 2005 i did a search before i made a topic... and it only found 3??? maybe my searches did not work... at least now i know there is a chart and i can always google it now..thanksglen Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted August 16, 2005 Report Share Posted August 16, 2005 What sort of capacitor is it?Electrolytic?Ceramic disc?Tantalum?Tantalums and electrolytics are polarised and will be even more of a problem if the polarity markink has worn off in which cas I'd dispose of it.Do you have an oscillossope or frequency counter?You could build an astable 555 timer oscillator with a known value resistor then measure the frequency of the output, and work out the capacitor value from the 555 frequency formula. Quote Link to comment Share on other sites More sharing options...
ECET0purdue Posted August 16, 2005 Author Report Share Posted August 16, 2005 they are all electrlytics well at least 90% just they all were separate then it got knocked over so now i have like 50 different caps all together while some have the value on them and others dont. Maybe makeing a circuit with a 555 is too much work for them... thet sad there was a iec code but i could not find a chart or online calulator for them.thanks,glen Quote Link to comment Share on other sites More sharing options...
MP Posted August 17, 2005 Report Share Posted August 17, 2005 Here is a link that might help you.http://www.uoguelph.ca/~antoon/gadgets/caps/caps.htmlMP Quote Link to comment Share on other sites More sharing options...
