Jump to content
Electronics-Lab.com Community
positive and negative voltages
chasmith17
Hi there chasmith17, velcome to this forum
About your question, no, not easily :(! But if you mean from a transformer, yes, its easy! If you have a transformer with only one secondary you can use halfwave rectifiers, just ground one of the transfomer output wire and connect diodes to the other and if you prefer a fullwave rectifier you must use a transformer with double the voltage and a centertap, just ground the centertap and connect the other two wires to a rectifier bridge. The negative output from the bridge is the negative rail and the positive output from the bridge is the positive rail.
//Staigen
Link to comment
Share on other sites
There are many specialized ICs and modules around that'll do this but here is a way to do it using normal off the shelf componants.
Here's another way of doing this but you loose 1.4V in diode drops, and there'll be more ripple on the output too
Make sure the 100uf capacitor is rated at least to twice the maximum supply voltage.
Link to comment
Oh, you wanted a +12V to -12V converter! As Alun show you here, this is a simple one, but lack exactly center of the ground, and is not nessarily in many cases. But i would connect the positive terminal of the 100uF cap at ground instead of connecting it to the positive terminal. And use ordinary 555:s, not the cmos type. And, it can't supply much current!
//Staigen
Link to comment
An LM7912 doesn't make a negative supply, it is not a generator. It just regulates a negative supply that is already there. Its input voltage must be at least -15V for it to work perfectly. ::)
Darn... you are right...  :-\
But I am sure I have seen a similar circuit in the LM7800 series datasheet. Producing negative voltage from an LM78xx.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
