Jump to content
Electronics-Lab.com Community
30vac to 30vdc converter
I am working on a project that requires dc volts. Currently my power supply generator is 30vac @ 32 amps. I would like to know if there is a way that I can transform the 30vac to 30vdc and keep the 32amp range. I would appreciate the help from anyone that can offer it.
PS. I have not worked with circuits since i was in junior high school (very long time ago), I suppose that once I can refresh my memory, it should get easier.
Link to comment
Share on other sites
To do this with this efficiency you'll need to build a switch mode power supply which will be noisy and they're not the easiest things to build either, what do you wish to power with your power supply?
Link to comment
That's funny I calculated with  a rectifier to be for 30Vin @ 32A:
Vout = 30 * 1.414  - 1.4 = 41.026V
Iout = 32 / 1.414 = 22.627A
Pout = 928.295W
Efficiency = 928.295 / 960 * 100% = 96.697%
This could be improved by using high performance ultra low voltage drop schotky diodes for the rectifier.
If we assume 90% for DC-DC conversion in this example the total efficency will be:
0.96697 * 0.9 *100% = 87.03%
However if you used the best componants money could buy DC-DC is 95% efficent so:
0.96697 * 0.95 *100% = 91.86%
Having said all of this you're right I'd expect about 80% efficiency for this whole circuit using normal cheap and nasty componats. ;D
Link to comment
thanks for the input, i do apologize for placing this question in the projects section. my goal it to have at least 90 volts and 160 amps on the end side of the power equation. I was planning to put together enough psu together in parallel and series to achieve this end volts and amps. I know it is quite a project, but I feel I can accomplish it. My goal is to power a dc motor. The motors data is 72-120vdc 130amps cont 150 amps/hr 500amp peak. I know that once i have completed my psu it should take up an area of 3'x4'. I understand that I will have some losses somewhere, but i am not sure where and how much. I was planning on using 15 psu's, me being optomistic and little experience, i was hoping to get the 90vdc @160amps. I greatly welcome your design, ideas, help, and suggestions. As well as info on what components you guys would recommend for my build, ie capacitors rectifiers and diodes.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
