jitender Posted November 14, 2005 Report Posted November 14, 2005 Basically i want to knw the corresponding waveform of unipolar PAM.I wud be extremely greatful for u.Jitender Quote
prateeksikka Posted November 14, 2005 Report Posted November 14, 2005 hi jitender!if i am not mistaken u are talking about pulse amplitute modulation.The amplitude of same ,symmetrical pulses is varied in accordance with modulating signal.just like AM .but it is pulses as carrier rather than a sinusoid. ;D Quote
walid Posted December 4, 2005 Report Posted December 4, 2005 Read this pdf file I hope it will help u:www.comlab.hut.fi/opetus/245/2004/07_digibaseb.ppt Quote
ante Posted December 4, 2005 Report Posted December 4, 2005 Hi guys,This is not a PDF file it’s a PPT file, you need Microsoft Power Point to view this file! ;) Quote
audioguru Posted December 4, 2005 Report Posted December 4, 2005 I worked with a huge intercom system that multiplexed many conversations and background music internally along a single wire using PAM. The instantaneous amplitude of each conversation was sampled in its time-slot then a sample-and-hold stage held it until the multiplexer came around again to its time slot for the next sample. Of course, the multiplexer operated at a very high frequency. After being decoded in its time slot and filtering, it sounded nearly perfect.I had to soup-it-up so it met the strict "broadcast quality" spec's for the PA at international airports. Nearly CD quality sound. ;D Quote
prateeksikka Posted December 6, 2005 Report Posted December 6, 2005 hi audioguru!i guess we hardly use PAM for digital modulation i guess PTM has more advantages.and know one thing,i just came to know that there is a fallacy in the name itself of PCM(it is not a modulation scheme)!cheers! Quote
