Jump to content
Electronics-Lab.com Community
Differential amp vs op-amp
Guest 4electros
A single opamp used as a differential amp isn't useable because negative feedback to its inverting input causes that input to be a low impedance much less than its non-inverting input.
Therefore 3 opamps are used, with 2 opamps at the inputs of the differential amp. Then the circuit has a high input impedance and a balance of its inputs.
Link to comment
Share on other sites
Guest 4electros
the first image includes a single op-amp used as diffamp and the second includes two opamps connected to the inputs of the third diffamp so to make it balanced , the third image as same to second with a bit little difference ...
but the third diffamp  also have negative feedback connected to its inverting input so does that affects the impedances at its inputs and make the diffamp non- balanced
i need more clarify about, with all my respects!
thanks a lot!
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
