Jump to content
Electronics-Lab.com Community
Transistor BF 494
i wish to ask again  :-[ :-[ :-[ i am not good in electronics  :-[ :-[ :-[ can i for the schematic  of veronica 1w pll pro use 2N2219 or 2N3553 or something equvalent instead of the BF494??? my local shop has nt  BF494 or BF 184 thanks a lot :-[ :-[ :-[
and can anyone suggest a page for transistor equivalent plzzzzzzz
Link to comment
Share on other sites
Hello Mettula
  I am new to electronics too and understanding the difference in transistors is a project all in its own. I found the data sheet for the BF494 and will post it. And try to come up with something for. Boy wish I could find data sheets for my collection or transistors.
                          good luck
                                    gogo
42501001.pdf
Link to comment
Thanks audioguru
            I will give a try. Right now I am in hot persuit of info on a power transister  SK  B1382. Just because I have one and I want to see what it can do. I hope that makes sense.
                                    Thanks gogo
Link to comment
Thanks audioguru
    I didn't find it at data sheetarchive, but I did a search string on 2sk1382 and found the data sheet at
http://katalog.elektroda.net/indx450-2SK.html
  nice I got it. With your help
                                  Thank You
                                        gogo
e001347.pdf
Link to comment
Hello Staigen
    Your right about the BF494< I checked mouser and they have it for 20 cents.
        I check the data sheets on th 2SB1382 wow what a difference between it and the 2SK1382. The transistor Has SK under lined on top of the part number, So I am guessing that it was made by Sanken.
                                              Thank You
                                                  gogo
Link to comment
Hi mettula
Where in the world are you living, the BF494 is one of the most common HF-transistors in the world! ;D
//Staigen
Staigen i live in Gozo a sister island of Malta - here few are in the rf field and many times for a school project or hobby we have to import components from abroad which makes projects expensive. some shops do provide help but sometimes this forum helps better  ;D ;D ;D
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
