sinn Posted March 28, 2006 Report Posted March 28, 2006 Hi,first of all, i'd like to say it's been an interesting read of the forum topics.I'd like help on something.I have a nickel coil, that glows hot due to high pressures within an internal combustion engine. The two ends of the coil aren't linked to anything; the coil only glows because the pressures are so high, and not because of a current induction or anything.Since the two ends of the coil are free, is there anyway that I could wire up the coil to something that would limit it's heating under the high pressures?? Would Infra Red emitting nicket respond to any type of frequency of some sort.I'd like to be in a position where I could apply some sort of input (within the two ends) and prevent the coil from heating up.I hope this doesn't sound too odd ::) Well it's worth asking ;DLooking forward to any ideas / suggestions. thanks all!! Quote
steven Posted March 31, 2006 Report Posted March 31, 2006 :)extend the coil ends and wrap it around a peace of alliuminium a large heatsink , or run the coil ends into some coolant like that used in ya radiator of your car Quote
jtamminen Posted May 3, 2006 Report Posted May 3, 2006 There is *currently* no way to extract energy away from the coil ;(To my mind this is a glow-plug in a model-engine, that runs with methanol. The combustion cycle generates the heat that keeps the coil hot, and that ignites the next cycle again, getting heat from burning to be able to ignite again.The plug is not connected to power after startup. But to cool it down requires either cooling, or stopping the engine with other means.Mechanically that is very hard to do. Maybe a custom-made plug, with some kind of screening mechanism for the coil? Or removing the coil far enough from the combustion chamber into some pipe? Quote
audioguru Posted May 4, 2006 Report Posted May 4, 2006 Glow plugs for model engines are (were) available with different heat ranges. Ones that idled well had poor high speed performance and the other way around. Quote
rybitski Posted June 27, 2006 Report Posted June 27, 2006 What is the purpose of stopping the IR? What is it interfering with? Or do you just have problem with light below the visible spectrum? Quote
fad Posted August 14, 2006 Report Posted August 14, 2006 u can stop it by using hard black rubber coating it can reduces u r coil heat as well as it can stop radiations bcz it absorbs all radiations Quote
Theatronics Posted August 15, 2006 Report Posted August 15, 2006 Black tape in a I.C.E? Sticky..I would like the question about (Why) answered. Maybe the IR or Heat isn't the real issue.Is there some 'sub-visual' bias gong on here?What little I know about 'glow plug' engines tells me that removing the coilwould cause the engine to stop working.So I guess that it it should be there, maybe it 'should' be glowing ?-Mike Quote
