mark Posted May 10, 2006 Report Share Posted May 10, 2006 hi to all I would like to ask if the tuner of television is the same with the tuner of a VCR? i need a proof that this two device has the same tuner...I wolud also like to ask if this is true can you give me a document that the tuner of TV and VCR are almost the same... The purpose is for our design project. We need to know the similarities between them.. thanks and i'll wait for your replyyy... Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 10, 2006 Report Share Posted May 10, 2006 Sure they are the same since they both receive TV. There is no reason for them to be different.In order to prove it then you must find the parts list of a TV and a VCR that uses the same tuner. Quote Link to comment Share on other sites More sharing options...
ZomBiE Posted May 12, 2006 Report Share Posted May 12, 2006 Most of them is supplying composite video and modern versions outputs nicam or A2 audio carrier, but then it gets more complicated because many of them uses different protocols of tuning: analog, I2C, or many variations of digital serial lines. analog mono signals are mostly analog voltage tuneable and datasheets are quite easy to get. Quote Link to comment Share on other sites More sharing options...
