Jump to content
Electronics-Lab.com Community
can any one explain zener breakdown using energy band diagrams?
vamshi
  • 4 weeks later...
zener breakdown only occurs in zener diodes with a volatge below 5-6V. above which avalanche breakdown occurs. zener beakdown occurs in highly doped semiconductor junctions where the depletion region with is very small. the breakdown occurs due to high electric field across the depletion region (E=V/w) since the depletion width w is very small the electric field is very high which leads to rupture of covalent bonds which leads to carrier generation which is a cascading effect and leads to zener breakdown. Avalance breakdown is in lightly doped junctions in which the minority carriers strike the atoms releasing more carriers and thus cascading this effect leading to avalanche break down.
u can refer to some good books on semiconductors by authors like M.S.Tyagi, S.M.Sze, Ben G. Streetman. we used to study these in our graduation and masters. :D
Link to comment
Share on other sites
Avalanche breakdown occurs in all diodes!!! It's just a question of how well the breakdown voltage level is controlled (through doping levels). Reverse bias any "plain Jane" diode and it will work just like a zener, reverse the polarity across a zener, and it will behave just like a diode. The "zener" is just a "special case" of a "regular" diode.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
