Guest nanop Posted August 19, 2006 Report Share Posted August 19, 2006 Hi,I heard about a vocal remover circuit, it would remove the vocals from most songs. Can u tell me how it works?Know of any or have any vocal remover circuits?Thanks a lot Quote Link to comment Share on other sites More sharing options...
audioguru Posted August 20, 2006 Report Share Posted August 20, 2006 Vocals in a recording are usually on both stereo channels at the same level (in mono). A vocal remover circuit adds the frequencies of voices from the other channel out-of-phase so it cancels the same signal in the channel that is in-phase. When music is normally different on each stereo channel then the music doesn't cancel. The mono bass is filtered out of the adding circuit and goes unchanged.Go to Google and search for Vocal Remover Circuit and the 1st link is a kit with a parts list, pcb and schematic. Quote Link to comment Share on other sites More sharing options...
Guest nanop Posted August 20, 2006 Report Share Posted August 20, 2006 A vocal remover circuit adds the frequencies of voices from the other channel out-of-phase so it cancels the same signal in the channel that is in-phase.Can u explain to me more about how this works?Thanks Quote Link to comment Share on other sites More sharing options...
audioguru Posted August 20, 2006 Report Share Posted August 20, 2006 Can u explain to me more about how this works?Both stereo channels have the vocals at the same level (in mono) and both are in phase.The circuit takes the 1st channel's vocal sounds, inverts their phase with an opamp inverting amplifier then adds them to the 2nd channel's original sound. Since the sounds are the same but with the opposite phase then they cancel.Normal stereo music is different on the two stereo channels. Therefore it doesn't cancel. Quote Link to comment Share on other sites More sharing options...
MP Posted August 21, 2006 Report Share Posted August 21, 2006 You can get a vocal remover patch for Winamp here: http://www.analogx.com/contents/download/audio/vremover.htmIt uses a digital algorithm instead of hardware.MP Quote Link to comment Share on other sites More sharing options...
Martin Lutharking Posted May 12, 2020 Report Share Posted May 12, 2020 Sir how convert sterio to surround conversion I have sterio signal but I want only music what can u do pls help me Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 15, 2020 Report Share Posted May 15, 2020 Stereo is recorded on 2 channels and surround sound uses 4 or 5 channels. There are some Oriental ICs that produce fake surround sound when the input is ordinary stereo. Some people think it sounds real. Quote Link to comment Share on other sites More sharing options...
admin Posted May 17, 2020 Report Share Posted May 17, 2020 There are some circuits online, mostly named as Karaoke Circuits but i am not sure how well they will perform. Quote Link to comment Share on other sites More sharing options...
Sugandhan Vazhumuni Posted May 29, 2020 Report Share Posted May 29, 2020 This is sugandhan from India @Geust nanop thanks to share Quote Link to comment Share on other sites More sharing options...
