Jump to content
Electronics-Lab.com Community
Posted
Hey everyone, Im new and was wondering if someone could answer a question i have about 555CN Timer IC's. Would this be what i would use to set a time on an LED, for instance having it turn on and off, What does a 555CN Timer IC do?
Thanks For the help guys. And I apologize for my newbniss
Posted
Generally, the 555 timer IC is not used for long-duration time events, but is, as you say, useful for turning things off and on, and is also used to provide a fairly reliable clock pulse.
Go to " 555 timer " on any search engine and you'll find all the information you need to use this little device.
  • 2 weeks later...
Posted
it has nothing but an RC (charging discharging circuit ) inside
It has a lot more than that!
Two voltage comparators, a flip-flop and a high-current output stage. Its schematic shows 28 transistors and 12 resistors but it could have more.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
