Jump to content
Electronics-Lab.com Community
FM deviation meter
AN920
I am building a FM stereo transmitter from a kit and need to measure my modulation or also called deviation when on air. Where can I find a circuit to do this? The only thing I found was here http://www.edmdesign.com/mic.htm where they use a small radio. Any idea what the "additional electronics" would be and how they do it?
If I use the VU meters on a FM receiver, how can I calibrate it at 75kHz modulation?
Link to comment
Share on other sites
Hi AN920,
I think the "additional electronics" takes the audio signal before de-emphasis and peak detects it with a peak detector like in the datasheet for the LM3915. You can add your two stereo channels and it probably doesn't need to be before the de-emphasis because high audio frequencies usually aren't loud. Your VU meter is probably not a peak detector.
They say that rock stations frequently peak at 80kHz so measure a few stations and average their outputs.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
