johnc12 Posted January 8, 2007 Report Share Posted January 8, 2007 hi guys,i have a two speaker that is in a box already and have a rated impedance of 6 ohms.... what amplifier could i use in the project so that i could use them on my computer system... thanks in advance... ;) Quote Link to comment Share on other sites More sharing options...
audioguru Posted January 8, 2007 Report Share Posted January 8, 2007 Hi John,Our 10W Mini Amplifier http://www.electronics-lab.com/projects/audio/016/index.html provides 1.9W into a 6 ohm speaker at clipping with a 12V supply. It is a mono amplifier project.Our 22W Audio Amplifier http://www.electronics-lab.com/projects/audio/006/index.html provides 6.5W into each 6 ohm speaker at clipping with a 12V supply. It is a stereo amplifier. Quote Link to comment Share on other sites More sharing options...
johnc12 Posted January 8, 2007 Author Report Share Posted January 8, 2007 thanks audio guru... i think i should use stereo amp... :) Quote Link to comment Share on other sites More sharing options...
johnc12 Posted January 8, 2007 Author Report Share Posted January 8, 2007 i forgot to tell that my speaker is branded sony.... it is use as satellite speaker in a component... in your 22W stereo amp... could i use both speaker left and right with the same rated impedance at once??? Quote Link to comment Share on other sites More sharing options...
audioguru Posted January 8, 2007 Report Share Posted January 8, 2007 The 22W Audio Amplifier project can provide 6.5W to each of two 6 ohm speakers at the same time. But satellite speakers are small and might be damaged if 6.5W of bass gets to them since they are usually used for only midrange and high frequencies with a separate powerful subwoofer playing the bass. You might need a crossover circuit so that the satellite speakers don't have bass frequencies. Quote Link to comment Share on other sites More sharing options...
