Jump to content
Electronics-Lab.com Community
newbie question
leedude
hmm..ok, i have refined the concept a little,
i need the power supply to accomodate an lcd(consumes about 250ma). The input must be a 9v battery, and it must produce an output of 5v. what should i use to build this supply? could i use this: http://www.maplin.co.uk/module.aspx?detail=full&ModuleNo=46321&doy=20m2#more_info
if so, what caps/other components do i use with it? a circuit diagram would be nice.
Link to comment
Share on other sites
What kind of LCD display consumes 250ma? It must have a very bright light in it.
A little 9V alkaline battery can supply 250mA for only a short amount of time. The low dropout 5V regulator will work fine for a little more than one hour.
The circuit diagram for the low dropout 5V regulator is in its datasheet that is in your Maplin link. Use two tantalum capacitors as shown.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
