Jump to content
Electronics-Lab.com Community
microwave oven service manual
hey guys im doing a school physics project on how a microwave oevn works
and im going to go in to a fair bit of detail of all the electronic components like the high voltage transitor and the special light needed and all about the magnetors.
so i was after a service manula on any moden microwave oven
and i was also hopeing to find a explosion diagram of a microwave oven
so any help at all about this assigmnent whould be great
if you got any links to sevrice manuals that would be great to
thanks alot in advance
Link to post
Share on other sites
that the links are great
but im having a bit of trouble understanding how the magnertron works
i know that current flows out the hot filament and the spirals around befor getting tothe anode becuase of the magnetic field
but im not sure about how the rest works
how the current goes into the cavitys and stuff ahppens in there which makes the microwaves.
can someone explain in a grade 11-12 level for my assigment
thanks in advance
steve
Link to post
The cathode is generally pulsed with a negative potential using a HV DC source, within the core of a circular chamber the latter cathode is placed.
Angular to the core a magnetic field is constructed which in turn allows the electrons to spiral out in a circular pattern to the anode.
Provided around the outer edge of the core are additional cavities, as the electrons pass the latter opening they resonate at a high frequency.
The circular pattern cause the electrons to push together (group).
A small amount is forced/directed to a metal tube (WG), the waveguide emits the high Freq RF energy to the cooking containment area for heat etc...
Actually, the above process is similar in relation to a klystron tube but much more efficient.
Although, a klystron is better suited for other applications; High power transmitter etc...
Final note: Use caution around any HF wave when experimenting since radiation is emitted in a dangerous manner when uncontrolled; dont take the path of  Madame Curie...
-Omni
Link to post
  • 14 years later...
I can advise you a company where you will find highly qualified specialists .Contact them https://jsbappliancerepair.com/simi-valley-appliance-repair they are engaged in repairing house appliances for more then 15 years. I think they have something to advise you. Because microwave ovens are also their specialty. Call them, they have a lot of information that will be useful in your project.
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
