owais86 Posted July 8, 2009 Report Share Posted July 8, 2009 Hi all Am working on a project for switching air conditioner A/C on and off through PC. The main idea is to use PC parallel port to switch the A/C. I have designed a circuit (schematic attached). As i have no experience of playing with [glow=red,2,300]mains[/glow]. So i need some comments/advise on this circuit will it work and how to make it safe. Thanks all Quote Link to comment Share on other sites More sharing options...
owais86 Posted July 8, 2009 Author Report Share Posted July 8, 2009 ;)Its working fine on ISIS 8) Quote Link to comment Share on other sites More sharing options...
Hero999 Posted July 8, 2009 Report Share Posted July 8, 2009 That will work, assuming the opto-isolator is rated to carry the relay current.It seems a bit overkill to use both an opto-isolator and a relay. I would have used either an opto-TRIAC triggering a TRIAC or a transistor and relay.Relays are more fail safe than TRIACs but have the disadvantage of requiring a power supply. An opto TRIAC triggering a TRIAC can take all the power it requires from the parallel port. Quote Link to comment Share on other sites More sharing options...
owais86 Posted July 8, 2009 Author Report Share Posted July 8, 2009 That will work, assuming the opto-isolator is rated to carry the relay current.It seems a bit overkill to use both an opto-isolator and a relay. I would have used either an opto-TRIAC triggering a TRIAC or a transistor and relay.Relays are more fail safe than TRIACs but have the disadvantage of requiring a power supply. An opto TRIAC triggering a TRIAC can take all the power it requires from the parallel port.So you mean that i should use opto triac like MOC 30XX....... and another TRIAC with it? Y 2 TRIACz? Quote Link to comment Share on other sites More sharing options...
Hero999 Posted July 8, 2009 Report Share Posted July 8, 2009 A typical opto-TRIAC can only take a couple of hundred mA which isn't enough for an air conditioner.It's up to you, you could use a transistor and relay if you like.All I'm saying is that it's wasteful to use both an opto-isolator and a relay. Quote Link to comment Share on other sites More sharing options...
