Kevin Weddle Posted February 2, 2010 Report Share Posted February 2, 2010 Can you compare the output of two parallel A/D converters and produce a better conversion? A comparator at the output of both A/D converters could produce more accuracy. An example is a differential opamp where common mode noise is eliminated by two inputs. Quote Link to comment Share on other sites More sharing options...
