Jump to content
Electronics-Lab.com Community
Active load circuit 5-8A
Hello.
I need an active load with current control to test my power supply (PSU is project here http://www.electronics-lab.com/projects/power/001/index.html)
I found schematic
But I contacted autor and he told me it's generally bad idea to copy becase it's not stable enough. He told me that the best way to avoid this problem is to delete IC2A and set voltage divider 1:22 on positive input of the IC2B.
But then, how would the schematic look like?
But i've got some other ideas. First of all i would like to replace voltage reference with LM317 (I've got 10 of those).
I think of replacing BC transistors by the pair of 547B/557B or 550C/560C, because i've got many of those. Is this good idea?
And finally i would like to replace FET transistor by any other I would find in ATX power supply (I've got like 50 and I think i might find some replacemant that could handle 10A.
I will of course do schematic in eagle but i need some help with this. Is there a place where I can measure voltage and calculate current limit? I think it should be close to the 5W resistor.
Thanks for the help in advance
Sorry for my mistakes, English is not my first language.
Link to comment
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
