Jump to content
Electronics-Lab.com Community
Posted
This gate driver is for a buck converter. The input to this IC is a nice pulse of frequency 100 KHz of variable duty ratio. I have checked the circuit many times and ensured that no shorting is there. But the output remains 0 volts. The output HO is hanging as well as the output VO is hanging. For the sake of step by step progress, I have left them hanging. Is there something I have missed or something I dont know that I should have done.
Guest Enforcer83
Posted
looked at the datasheet and assuming you are powering the chip (VCC) with a voltage between 10 and 20V and giving it a logic signal in the same range, there is no reason you should be having a problem.  The hookup you have given is as I have seen in the application circuit.
Posted
Your schematic shows that the Vcc pin is only connected to a diode anode, the Vcc pin also needs to be connected to a voltage (i.e. input voltage to the buck converter). If you don't connect Vcc to a voltage of course your not going to have a output!
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
