Guest Digonto Posted April 19, 2011 Report Share Posted April 19, 2011 Hello,I have a simple stupid question . Because I have not faced this parallel switch problem before . I have attached the diagram below . There is two switch "S1" and "S2" . Only one switch needed to run the Load . But my question is - If accidently both of those switch "S1" and "S2" are ON together, then what will happen to Load ??Will it burn my Light / Fan ??Please reply ........ I am in confusion ..... ??? ??? ??? Quote Link to comment Share on other sites More sharing options...
audioguru Posted April 19, 2011 Report Share Posted April 19, 2011 If your fan is made to use 230VAC then how can it burn?If one switch is turned on or both switches are turned on then the fan turns on.If both switches are turned off then the fan turns off.A "2-way" switch and its wiring are different. each switch in a 2-way switch circuit can turn the fan on or off. My family room has two doors. There is a 2-way switch at each door that can turn the lights on or off. Quote Link to comment Share on other sites More sharing options...
Guest Digonto Posted April 19, 2011 Report Share Posted April 19, 2011 Thanks Audioguru , thanks a lot . I was in confusion - will it be harmful to load or not ?? Because I did not do it before .Thanks Quote Link to comment Share on other sites More sharing options...
audioguru Posted April 19, 2011 Report Share Posted April 19, 2011 The switches simply turn on the fan or turn off the fan. It is not harmful.Why do you have two switches in parallel? Quote Link to comment Share on other sites More sharing options...
Hero999 Posted April 19, 2011 Report Share Posted April 19, 2011 This has got to be one of the funniest threads ever. :D Quote Link to comment Share on other sites More sharing options...
Guest Digonto Posted April 20, 2011 Report Share Posted April 20, 2011 ha ha ha ha ;D ;D ;D Actually I will use that in different condition where a parallel connection will appear . I can do that without parallel but If I make parallel, it will be more helpful to run Load from different position . I have shown that process with this simple Parallel switch diagram . :)Thanks guys . A lot of fun . ;D ;D ;D Thanks a lot ...... :-* Quote Link to comment Share on other sites More sharing options...
