Jump to content
Electronics-Lab.com Community
Posted
Not that it matters, 22pf or 27pf could be used instead.
Another reason for using many capacitors in parallel is it gives lower impedance to higher frequencies if they're spread across the PCB traces.
Posted
I understand from your words that if I had two caps, one of them is equal to 5p and the second = 10p.
Better to use the two in parallel to get 15p and not one 15p to make an easy path for the high-frequencies toward ground???
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
