Jump to content
Electronics-Lab.com Community
supply
new one
Are you  interesting in designing a circuit using mathematical equations or are you interested in building a power supply using proportional engineering (as a 6.3 volt filament transformer should work)? Proportional engineering is the  way I build most things.   Are you looking for help here?
Link to comment
Share on other sites
The 12 volt transformer supplies a peak voltage of:
Vpeak = 12 * square root of 2 = 12 * 1.4 = 16.8
With 16.8 volts into the bridge we subtract 0.7 volts for each diode. As the current
passes through 2 diodes for 1.4 volts.
Vdc = 16.8 - 1.4 = 15.4 without a load.
The actual loaded voltage will be more likely around 14 volts as we will see later
with a capacitor and load. I am using 20ma LED here.
For the capacitor:
ripple voltage Vr:
Vr = (0.0024) * I/C  = 100 mv
C = 0.0024 * I / Vr  =  0.0024 * (0.120A / 0.10V)  = 0.00288 F
0r: C = 2880 micro-farad
from Schertz and Monk "Practial Electronics for Inventors" section 11.6
For a Zener diode
Lets try the 5.1 volt 1N4733A. As 5.0 volt Zeners are hard to find.
For the 1N4733A Zener diode the value of Vz is 5.1V and Pz is 500 milliWatts
now with a Vdc (dc supply voltage) of 14V the value of R2 will be:
Rs = (Vdc - Vz)/Iz
Rs = (14 - 5.1)/Iz
Iz = Pz/Vz = 500mW / 5.1V = 98mA max.
Thus Rs = (14 - 5.1)/98ma = 90.8 ohms
Rs = 91 ohms (approx)  91 ohms is a standard.
The power/watts into R2 will be:
Pr2 =  V^2/Rs = ((14 - 5.1)^2)/Rs = (8.9 * 8.9)/91 =  0.87 watts or 2 watts in practice.
So with a load of 120 ma the voltage drop across Rs:
Vrs = 91 * 0.12 =  10.92 volts ........oops! Looks we only have 14 - 10.92 = 3.08 for
the load and the  Zener is out of business!
Lets try a 1 watt Zener and 5.1 volts:
Iz = 1.0  watt / 5.1 volts = 0.196 A or 196 ma.
Rs = (14 - 5.1)/ 0.196A =  45.4 ohms or 47 ohms standard
Voltage drop across Rs at full load:   Vrs = 47 * 0.12 = 5.4  volts;
Or 14v - 5.4v =  8.6 volts for the Zener to chew on.
Pr2 =  V^2/Rs = ((14 - 5.1)^2)/Rs = (8.9 * 8.9)/47 =  1.685 watts or 2 watts or better in practice.
Next we can run this through the simulator and see what it looks like. (to be continued).
Link to comment
Doing a prototype of the circuit as shown below using a voltage regulator as I have no 5 volt Zeners:
I used 1N007 diodes and a LM7805 regulator. Transformer output 13.85 Vac 17.3 Vdc at the capacitors.
What I got for ripple voltage at the capacitor was:
  • 536 mvpp with 1523 mfd cap.  140 mv ac with multimeter
  • 288 mvpp with 3005 mfd cap     71 mv
  •  200 mvpp with 4454 mfd cap.   48 mv
  • 140 mvpp  with 6050 mfd cap    36 mv
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
Important Information
We have placed cookies on your device to help make this website better. You can adjust your cookie settings, otherwise we'll assume you're okay to continue.
