saveearth123 Posted February 1, 2022 Report Share Posted February 1, 2022 i need low voltage sensors that will detect when something about the size of a tiny finger passes through a beam. They will also need to be compatible with a low voltage load - about 5 volt dc. likely small relays will be needed. this is all under water but enclosed without water. this is for an aquatic project. the beam distance does not need to be more than one or two inches. no life will be harmed, of course. i see lots of sensors rated for something in your back yard or at your garage door available. Quote Link to comment Share on other sites More sharing options...
HarryA Posted February 1, 2022 Report Share Posted February 1, 2022 I used a infrared transistor as a detector and diode emitter to make measurements on my quadcopter by having the blade pass through a gap with one on each side. You can get similar optical detector devices already mounted in pairs and separate them I would think. See this one for example: https://www.ebay.com/itm/402866611861?hash=item5dccb8a695:g:uUEAAOSwby1gql8L or unmounted: https://www.ebay.com/itm/274298671466?hash=item3fdd79916a:g:j~YAAOSwWNNdp9Dl The data sheet with circuit can be found here: https://www.digikey.com/en/products/detail/omron-electronics-inc-emc-div/EE-SG3/31139?s=N4IgTCBcDaIAQHkBKBWADAFgLQDkAiIAugL5A Perhaps an enclosure like this? Quote Link to comment Share on other sites More sharing options...
