Joh Drinda Posted June 17 Report Share Posted June 17 Since these starters are very expensive, I thought of soldering a few myself. I saw a SIDAC circuit and bought a few of them, but it failed to work! I must be doing something wrong! My tube has no capacitor. Maybe it's that why it won't work? Here's a page that shows more of how they work: https://www.bristolwatch.com/ele/sidac.htm I'm in N-Australia and we got 240VAC, so I built this circuit: Quote Link to comment Share on other sites More sharing options...
HarryA Posted June 19 Report Share Posted June 19 I am confused with the two SIDACs (Silicon Diode for Alternating Current) in series. They are rated 220-250 volts switching each. 240 mains voltages would be in the order of 340*1,4 or 480 volts peak. About the same as the two SIDACs; not much to switch with? "These tasks of the starter are taken over by two 135 V sidac (or a single 270 V one). The starting voltage is thus 270 V, Which is below the peak value of the mains (about 340 V), but higher than the working voltage of a 20-40 W neon tube." see: https://circuit-diagramz.com/sidac-neon-tube-starter/ I will look at the circuit some more. Quote Link to comment Share on other sites More sharing options...
