petercl14 Posted January 22 Report Share Posted January 22 Hi, Can't get this project to work. Not uploading. I am using atmega328p mcu ic with arduino uno bootloader from jaycar. cat zz8727. Using uno com3. What is the programmer? Tried avr isp, avrisp mkll, arduino isp, arduino as isp. None of these work to upload my program. Can anyone help? Quote Link to comment Share on other sites More sharing options...
HarryA Posted January 22 Report Share Posted January 22 Are you using the information from Jaycar site? There is lot of information on their web site in Specifications and Articles. https://www.jaycar.com.au/atmega328p-mcu-ic-with-arduino-uno-bootloader-and-16mhz-crystal/p/ZZ8727 The manual is here: https://www.jaycar.com.au/medias/sys_master/images/images/9794372567070/ZZ8727-manualMain.pdf Quote Link to comment Share on other sites More sharing options...
petercl14 Posted January 23 Author Report Share Posted January 23 Hi Harry, I have already looked into all those references. I think I must have the wrong port. I have seen one reference where burning the bootloader you use a com 18 port. I don't have to burn a bootloader as the atmega 328p already has a uno bootloader preinstalled.When you pick the programmer you always seem to get a com port that goes with it. Perhaps I should be looking for the programmer with a com 18 port? I have also seen a reference where you take out the MCU from the uno board and replace it with the MCU you want to program. The idea of this is that then you can use the USB to serial converter on the uno board. But in the project from electronics lab you have a converter so you don't have to do that. And another problem is in removing MCUs with so many pins as it is so easy to bend the pins. Please let the author of the project give more details. He makes no mention of the program to use. Quote Link to comment Share on other sites More sharing options...
petercl14 Posted January 23 Author Report Share Posted January 23 3 hours ago, petercl14 said: Hi Harry, I have already looked into all those references. I think I must have the wrong port. I have seen one reference where burning the bootloader you use a com 18 port. I don't have to burn a bootloader as the atmega 328p already has a uno bootloader preinstalled.When you pick the programmer you always seem to get a com port that goes with it. Perhaps I should be looking for the programmer with a com 18 port? I have also seen a reference where you take out the MCU from the uno board and replace it with the MCU you want to program. The idea of this is that then you can use the USB to serial converter on the uno board. But in the project from electronics lab you have a converter so you don't have to do that. And another problem is in removing MCUs with so many pins as it is so easy to bend the pins. Please let the author of the project give more details. He makes no mention of the program to use. Hi Harry, Problem fixed. The usb to serial device I received had a switch which wasn't on the device shown in the project. Also had a dtr pin not on the project. This meant data received. I connected it the same as the rts pin in the project with the capacitor connected to reset pin on MCU. No problem with this. The problem was the switch apparently as this was set to 3.3v. When I connected to 5v and used uno as the program, the download worked. Now will be able to use jaycars zz8727 in many projects. Thanks for your interest. Quote Link to comment Share on other sites More sharing options...
