Jump to content
Electronics-Lab.com Community
MOSFET Power module and gate drive connections guidance
mumartahir
Hi, I have the following gate driver module ( EV1909-TL-00A) and MOSFET power module ( F4-15MR12W2M1_B76 ). I need guidance how to connect them and the connection schematic to drive the full bridge power module. The links to the datasheets are the following (I am also attaching the files):
https://www.infineon.com/dgdl/Infineon-F4-15MR12W2M1_B76-DataSheet-v02_00-EN.pdf?fileId=5546d4627956d53f01797a3e06e651f5
and
https://www.monolithicpower.com/en/documentview/productdocument/index/version/2/document_type/Datasheet/lang/en/sku/EV1909-TL-00A/document_id/11022/
I have a heat sink and will install both (the power module and gate driver board) on the heatsink. If you will provide me with a schematic and connection guidance to drive that module, I will highly thank full to you.
Best Regards:
Umar
Power module.pdf Driver board.pdf
Link to comment
Share on other sites
  • 3 months later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
