Oooh,. sorry, been a while since I read through this thread. (I guess I should've looked up that part number.)
No problem Mitch
A TVS diode, treat it almost like a zener. That guy should read as an open until you apply >= 15V to it. Then it will start to conduct. What kind of voltage are we talking about on those pins?
Edit: And hey, those joints don't look bad at all for a cheap iron!
Nicely done.
That's whats weird the guys at Vishay were able to tell me that the part that burnt out was a smbj15A but I was a little hesitant to believe that because there was no polarity markings and the diode when still attached and somewhat functioning (even though it was puffed) had resistance in one direction and an unequal resistance in the other direction. Keep in mind the other three diodes on the board with identical markings had equal readings forward or reverse! I could only conclude that this part was a bidirectional diode.The closest thing I could get my hands on was a sa15ca
And it's not exactly two diodes in series, reverse of eachother... it's two
zener diodes in series, reverse of eachother. While one is forward biased, and passes current normally, the other goes into avalanche mode at a certain voltage and passes current.
