Hello, and thanks for any help you guys can give me on my project.
First a little background so you can see what I want to accomplish in the end. I tend to run on a bit so please skip the next couple paragraphs if you want to get right down to business.
For my midlife crisis I decided that I enjoy building models and in the last couple years have built a couple dozen star trek models. At some point I converted an extra bedroom into a home theater room where I can watch my shows while models are flying around the room. I painted the ceiling and 3 walls black, put some rope lighting up, and have been hanging them from the ceiling. It looks cool (ok it looks nerdy), but not cool enough.
As the centerpiece of the room I bought a humongous 1:350 Enterprise (I only hope mine turns out half as well as the one in the link) and decided it had to be lit. Then I realized the rest of them would look pretty crappy and decided to rebuild all the models again and light them all. Plus I need a lot more practice at modeling (and wiring) before tackling the big one.
I have bought a bunch of the models again, and a couple lighting kits so far, and am building the first of the lighted ships.
_____________________________________________________________
Now, here is where I need some help planning. I have successfully modified an ATX power supply so that I can just wire up whatever I want it to power. This is where I got my only recent knowledge of electronics. I am using it to power some fans on a spray booth I just built and plan to mod 2 more for this project. One for my bench and one to power all the models.
Here is my plan:
I will be introducing each new model as it is built, meaning at first there will be one kit on the circuit and at the end there will be 10, 12, or more.
The kits each run between 6 and 9v. I have done a little reading and found that I can use either voltage regulators or just beef up my resistors to slow down the juice.
I also will be using an ATX PSU on my bench to test these models as I am building them so adding proper resistors or a voltage regulator to the kits will have to be first on the list.
My concerns:
1. After many ships are on the circuit, will the ship on the end of the line get enough power?
2. How do I properly reduce the current to each model?
3. Any other suggestions will be appreciated.
Here is my plan:
My concerns:
