Hello, what I'm trying to do is to make a cable that ends both sides with a USB-Female out of two cables that end with USB-Male from a side and a Female from the other side.. I have tried to cut both cables halves and reached the 4 wires inside then I tried to connect same wire colors with each other but what I found was that the first cable had Black - Green - Yellow - Blue inside and the other had Black - Green - Yellow - Brown.. So, I connected Black-Black, Green-Green, Yellow-Yellow and Blue-Brown and then I connected my phone which has Android OS from a side and a USB stick from the other side but it didn't work
also tried with iPhone 4 and it didn't
I also tried to connect a USB mouse but nothing worked.. Is there something wrong with the wiring? or do you have another method that I should try??
Please!!! I suck at soldering so please don't tell me to solder, connecting wires will do it
Your help is really appreciated and thanks in advance!! tc
