Help making pcb for this camera
Karimhes
Oct 18, 2014
5
Hey guys
i need your help please i am working with arduino project to make live vision
i want to ask you if it is possible to make a pcb for this camera which i disassembled from a sony smartphone or use adapter or something i don't even know the socket of it
Thanks so mush
Arouse1973
Adam
Dec 18, 2013
5,178
What is the pitch between the pads on the camera?
Adam
Arouse1973
Adam
Dec 18, 2013
5,178
I don't think the camera would handle the head associated with reflow, it might melt the plastic. So you could, but it's not ideal get some Sil strips 1mm pitch and solder them to the pads, put a nice bit of solder around the pins, it will be fragile so be careful. You could then make a PCB for this. I would personally see if I could solder some wires to the pad and use that instead. You could add a small amount of Tak-Pak to the wires to help secure them.
Adam
BobK
Jan 5, 2010
7,682
I would attempt to solder that to a PCB as follows:
Make the pads about 3/4 the width of the pads on the camera. This is so you don't short together 2 pads, which are very closely spaced on the camera.
The pads should extend about 1 mm beyond the end of the camera outline.
Fill up all the pads with paste solder and carefully place the camera centered on the pads.
Now touch each pad briefly with a small conical tip on the soldering iron to melt the paste solder.
I have used this technique with surface mount LEDs that are square and have similar pads, but, of course, not nearly so many.
Bob
Karimhes
Oct 18, 2014
5
Thanks for your help Bob and Adam i will post pictures of it when am done
thank you guys.
Arouse1973
Adam
Dec 18, 2013
5,178
Bob
Good Idea Bob
