the camera is 8x8 i salvaged from a sony smart phone the pitch is 0.90 mmWhat is the pitch between the pads on the camera?
Adam
Good Idea BobI would attempt to solder that to a PCB as follows:
Make the pads about 3/4 the width of the pads on the camera. This is so you don't short together 2 pads, which are very closely spaced on the camera.
The pads should extend about 1 mm beyond the end of the camera outline.
Fill up all the pads with paste solder and carefully place the camera centered on the pads.
Now touch each pad briefly with a small conical tip on the soldering iron to melt the paste solder.
I have used this technique with surface mount LEDs that are square and have similar pads, but, of course, not nearly so many.
