Does electron die?
Status
Not open for further replies.
RRITESH
Oct 10, 2010
85
Hello,
We generate electricity from Hydro power DAM /photovoltaci cell and then we get fan rotating.
there is circulation of electron after fan where it go?
Alec_t
Jul 7, 2015
3,817
Generating electricity doesn't actually create electrons; it just causes existing electrons in conductors to move around a circuit.
BobK
Jan 5, 2010
7,682
Yep, for each electron you put out, you have get take one back. Sort of like enforced recycling.
Bob
davenn
14,470
Bob
in a DC circuit, yes, they move VERY slowly around the circuit from the negative terminal to the positive terminal
but in an AC hydro generator system, the electrons never leave the generator, they just oscillate back and forward about a point in the wire
same with the ones in your AC house lighting and any other device
Dave
RRITESH
Oct 10, 2010
85
So, we have lots of electron near us?
The electron move from negative to positive side.
why we say current in positive to negative?
So, why we say crisis of electricity if there is lot of present electrons?
In DC circuit the voltage is low so pressure is low they move slowly in AC they move very fastly due to high voltage pressure?
And in ac the oscillation is 50/60hz?
hevans1944
Hop - AC8NS
Jun 21, 2012
4,968
So, we have lots of electron near us? ...
Electrons surround every atom in everything. The electrons in your feet (or shoes) support you because they are repelled by electrons on the ground beneath your feet. We live on a sea of electrons that shield the positive nucleus of every atom.
...The electron move from negative to positive side.
why we say current in positive to negative? ...
You can blame Ben Franklin, an American statesman, philosopher, scientist, inventor, and lady's man for that. He had to pick a direction for current flow and he picked positive to negative. Ben didn't know about electrons and their negative charge. But as long as you are consistent, it doesn't matter which direction you pick for the direction of current flow. Get over it.
... So, why we say crisis of electricity if there is lot of present electrons? ...
What crisis of electricity? In Ohio they use a lot of coal, gas, oil, and nuclear fuel to make electricity. The electrons are just along for the ride. They don't create any energy by just being there. You have to create electrical energy from some other form of energy such as the momentum of falling water, or the heat from hot water, or the energy in photons of light collected on a solar voltaic cell.
In DC circuit the voltage is low so pressure is low they move slowly in AC they move very fastly due to high voltage pressure?...
No, the electrons move about as fast in DC circuits as they do in AC circuits. It's crowded inside those wires, and the electrons have to make their way through the crowd at about the same speed no matter which way they are moving. They move at about the same speed you can walk. The electric field that moves the electrons propagates much faster, nearly at the speed of light in a wire.
... And in ac the oscillation is 50/60hz?
Mostly. Aircraft may use 400 Hz (need smaller, lighter, transformers and alternators and motors at that frequency) and there are other industries (trains for example) that may generate AC at whatever frequency they deem appropriate. But for commercial power distribution it is mostly 50 Hz and 60 Hz.
davenn
14,470
more than you can count
do you know what an electron is ?
it's an old thing, current flow direction was established long before the existence of electrons was known
elaborate on what you mean by that ??
In DC circuit the voltage is low so pressure is low they move slowly in AC they move very fast due to high voltage pressure?
not quite .... again google electrons and discover what they are about before we describe what happens in a circuit
for most mains power systems, yes ... some countries use 50Hz generation systems, some use 60 Hz
The country I'm in uses 50Hz
Also be aware the term AC (alternating current) isn't confined to mains power systems
an audio signal is an alternating current, the voltages and currents in a radio transmitter or receiver are also alternating
and usually much higher in frequency than the 50/60 Hz of mains power
FM radio, for example, works on 88MHz to 108MHz
Dave
RRITESH
Oct 10, 2010
85
Hello,
I know this electron is negatively charged.
ok,
I was talking of different country and news non renewable source are finishing.
The Electron are sitting between copper wire let say wire strands.
and it depends on type of cable.
RRITESH
Oct 10, 2010
85
Is there alternator like we have in vehicles in aeroplane also?
why it is rated at 400hz they build AC
new term 787 li-ion battery in it from google.
what electrical engineer has to do job with aeroplane in it?
In AC the electron oscillates what happen at different current.
dorke
Jun 20, 2015
2,342
Hop,
"They[Electrons] move at about the same speed you can walk".
They actually move much much slower than a snail...;)
The drift velocity of electrons in a copper wire is in the order of 10E-5 m/S
(1Ampere in a 2mm diameter )
It is dependent on the current density,the higher the current ,the higher the velocity.
RRITESH
Oct 10, 2010
85
Hello,
new term drift velocity OK, i have studied about in class but was not sure with meaning at that time.
higher voltage or current?
A calculation shows that the electron is traveling at about 2,200 kilometers per second. That's less than 1% of the speed of light, but it's fast enough to get it around the Earth in just over 18 seconds. Read up on what happens when nothing can go faster than the speed of light.
source
dorke
Jun 20, 2015
2,342
Hello,
source
The current density for a given wire(fixed cross section), translates to current.
If you apply voltage to a wire with a known resistance, you can calculate the current, but that is not important.
That velocity of 2200Km/sec is not in a conducting wire, and not of a free electron.
RRITESH
Oct 10, 2010
85
Then how to find Speed of electron in wire at different Voltage current?
Sadlercomfort
Ash
Feb 9, 2013
424
If you were to calculate the speed of the electron, for example to switch on a 240AC light. It would take like 7 minutes for the light to come on..
The electrons move slowly on a small scale, so what switches the light on instantly?
As the electrons move in the conductor it produces a electromagnetic field and its this disturbance which propagates through the conductor close to the speed of light.
It's convenient for us to understand a circuit where electrons are flowing.
Status
