I'm a beginner attempting to build a circuit and I'm starting to run out of ideas...
I need to get a somewhat high voltage and low current (above 2ma) through a 100k load with a small device.
I thought I could maybe use these small 1:4 and 1:10 transformers/coupled inductor to do the job:
1:10 Transformer
1:4 Coupled Inductor
With the circuit looking like:
40Ω Resistor is internal resistance
I get somewhat decent results.
Problem is when I enter the inductance as listed in the datasheet (not leakage inductance) as seen below, everything fails
Voltage and current on load drop drastically. All other parameters of the transformers don't cause problems.
Is there anyway to do this correctly? Or some other way to obtain the desired results? I'm not getting it...
1:10 Transformer
