- Joined
- Nov 17, 2011
- Messages
- 14,308
This is the expected value (25 V / 2.7 kΩ).When I change it to 10A slot, I read 0.01A for 3 sec
Check your multimeter. Looks like the 200 mA range is defect.on 200mA slot, I read overload ("1. ") for 3 sec
You use the 200 mA input in both cases, but for measuring 10 A you need to use the 10 A input.
Yes, voltage is stable. I changed the arduino code to max out the voltage at pin_8 just to see. Voltage is not flactuating.Is the output of teh step-up regulator stable
Voltage: https://streamable.com/jf68uj(constant voltage with and without load)
yes.Do you think if it is the resistor's smell when it gets super hot? Is this smell normal?
yes.
At 25 V the power dissipation in a 145 Ω resistor is P = V2/R = 625 V²/145 Ω = 4.3 W. YOu will need at least a 4.5 W resistor to withstand this power. Hot it will become anyway.
No. Not "no matter what".Do I need that resistor at collector end of the transistor no matter what?
no.Do I still need to add that 145Ω resistor?
Measured cold? When hot the grid's resistance will increase, lowering the current. In this case that's good.It has 341Ω resistance from one end to the other.
I measured the resistance at around 25 degrees Celcius room temperature, without any load. Therefore wires should be around the same temperature as well.Measured cold?
I'm afraid I can't read your picture well enough. Not a problem of my eyesight nor of the clarity of the image, but what it represents.
It looks like the end of the "+" wire and the end of the "-" wire are not connected. In that case, how would current flow through the wires from the connector's "+" to the connector's "-" pin? In post #8 you stated that the resistance of each grid is between 170 Ω and 340 Ω, depending on wire type. Without the ends of the wires being connected, the resistance would be infinite (well almost).
Yes, they are not connected. I will add terminal systems at bottom.It looks like the end of the "+" wire and the end of the "-" wire are not connected. In that case, how would current flow through the wires from the connector's "+" to the connector's "-" pin?
Then how did you get the resistance values you quoted?Yes, they are not connected.
When the ends of the wires are not connected the resistance is quasi-infinite and you don't need a beefy power transistor to drive voltage only to the grids. A small signal transistor like a BC107 alone can do that.
That measurement is useless, as there is no closed circuit for current to flow because you have left the end of the wire unconnected.I measured start of Frame_1(+) and end of Frame_1(+) and so on for each frame.
I have no idea how this contraption is meant to work. By electrostatic fields or by thermal effects from heating of the wires? Therefore I cannot answer your question with confidence.Are you saying that If I keep the ends not connected, It can still work? I
A schematic as in post #68 is much more helpful.I will take a photo tomorrow.
The solution: you need a driver stage like this:
Your first image is, beg your pardon, nonsense. As indicated below, all your resistors are short circuited and even if they weren't, they'd be in series, not in parallel
The latter clearly shows that the resistor R2 is connected to +5 V, not to the output of the LM2596 step-up module.
I meant the 5 V from the arduino.I am guessing you don't mean the 5V slot on Arduino so I need another battery(5V)?
There are many available. I used circuitlab for the drawings here. I also use LTSPICE from time to time.Also can you recommend me a software to draw circuits to simulate them?
