Sallen Key Low Pass Filter, bandpass filter
bertus
3,836
Hello,
Read the following thread on All About Circuits:
It shows you the use of the decoupling capacitors.
They should be as close as possible to the power lines of the opamps.
Bertus
Maglatron
Jul 12, 2023
2,025
Ok no its not making sense to me. My initial thought was to put the capacitors over the power supply but there is only 5 circuits connected together and there are 6 capacitors to add to the circuit. do you mind "drawing them in for me?"
Maglatron
Jul 12, 2023
2,025
powerlines as in 12v and REF?? and where does the electrolytic go?
or 12v and actual ground?
Maglatron
Jul 12, 2023
2,025
My internet connection doesn't allow me to download the pdf files from allabout circuits, could you post them here please? cheers
bertus
3,836
Hello,
To download the PDF's from All About Circuits, you will need to register.
After registration, you can download all pictures and PDF's from over there.
Bertus
Maglatron
Jul 12, 2023
2,025
I know what they're for to mitigate dips (ripple) on the power lines
Maglatron
Jul 12, 2023
2,025
I am registered there, it's my internet it restricts certain sites or sometimes downloads
bertus
3,836
Hello,
It is probably the VPN that you are using thet is ginving the problems.
Bertus
Maglatron
Jul 12, 2023
2,025
yeah I'm in hosptal so the hospital internet restrictions are out of my control, I can't even download a VPN!
Maglatron
Jul 12, 2023
2,025
I can't even log into email sites, sign on to youtube, paypal, skype and have trouble accessing certain stuff, mainly helpful stuff lol, it's a pain in the neck!!
Maglatron
Jul 12, 2023
2,025
I got my sister to sign up to allaboutcircuits for me and this site did not require email validation at all!
Maglatron
Jul 12, 2023
2,025
so I think I've worked out where the four of the 100nF's go, they go the shortest route between 12v in and the REF virtual ground of the filters, now I need to know where to put the 10uF cap, but im thinking that it goes in parallel with the 100nF across the 12v and actual ground of the buffer am I right? If so will it work as soon as I know I can get on with designing all of the filters! cheers
Maglatron
Jul 12, 2023
2,025
is it possible to change your name on allaboutcircuits because I want to call myself Maglatron:)
Maglatron
Jul 12, 2023
2,025
and where do the bypass filters go
Is this all correct!?
Maglatron
Jul 12, 2023
2,025
I can use TL074CN for the pre-amplifiyer, the filters, the buffer circuit and the enveloping detector circuit
how many buffer circuits would I need to use with 16 channels, do the LM3914 and the buffer use the same actual ground in the circuit and the signal from the enveloping detector circuit to pin 5 of the LM3914?
