Sallen Key Low Pass Filter, bandpass filter
bertus
3,852
Hello,
I see that R24 and R25 make a to heavey load on the detector.
You could remove R25 from the circuit for test.
Bertus
bertus
3,852
Hello,
Yes, I have the ZZZ collection. In wich folder is the LM3914?
Bertus
bertus
3,852
Hello,
LTspice is showing that it can not find the LM3914 on my side.
Bertus
Maglatron
Jul 12, 2023
2,025
I am still having the black box problem and for your problem with the LM3914 I don't know not sure can I give it to you??
Maglatron
Jul 12, 2023
2,025
I am still having the black box problem and for your problem with the LM3914 I don't know not sure can I give it to you?? extension .asy
when I hit run the box isn't popping up
  • LM3914 - Copy.txt
Maglatron
Jul 12, 2023
2,025
can I have it so that the preamp runs on 12v if you can edit the 9v version just for continuity with the power supply's
Maglatron
Jul 12, 2023
2,025
turned the computer off and on again and it is working again now but dead slow it's ok back to normal! did you get the file for the LM3914 that I sent, I sent it as .txt file you need to change the extension back to .asy!!
Maglatron
Jul 12, 2023
2,025
when I attach the circuit to the lm3914 the enveloping effect does not happen
Maglatron
Jul 12, 2023
2,025
do I need a capacitor between the envelope detector and the LM3914 perhaps?
bertus
3,852
Hello,
The RC time is to low due to the load.
Remove R25.
Bertus
Maglatron
Jul 12, 2023
2,025
I did do that already also my black box isn't loading up again, do you know whats up? do i have to wait till it gets to 100%1702226206687.png
  • compiled filter along with lm3914.asc
Maglatron
Jul 12, 2023
2,025
so if I change R18 will I have to change the C15 and C17 what should I set it to so that it comes under the 8.4v of the LM3914
Maglatron
Jul 12, 2023
2,025
this is supposed to be the envelope after the diode, I don't think that it looks right! its from this point1702226627221.png1702226524354.png
Maglatron
Jul 12, 2023
2,025
why is the black box taking so long to load up before it was near instant
bertus
3,852
Hello,
The load is still to heavy for the detector.
Place a buffer between the detector and LM circuit:
Bertus
