Sallen Key Low Pass Filter, bandpass filter
bertus
3,877
and how do you set it to 0v again? : audio is a positive and negative going signal.
What do you mean with set it to 0V?
The VCC- can get a ground simbol.
Bertus
Maglatron
Jul 12, 2023
2,025
thought as much but it's always best to check and so back to the novice question what type of caps do I use in the buffer circuit
Maglatron
Jul 12, 2023
2,025
sorry got mixed up
Bertus
I said how do you set the 0v I meant the negative pin I didn't know what you call it of the op-amp but you answered it strait away with "the VCC- can get a ground symbol"
Maglatron
Jul 12, 2023
2,025
so you mentioned that
Line level for consumer audio is about 0.9 Vpp:
With a gain of 5 the peak would be about 0.45 X 5 = 2.25 Volts.
The VCC+ is 12 Volts, VCC- is 0 Volts. REF would be 6 Volts.
Bertus
what comes from the pre-amp that will be and gets amplified to then go on to the filters to then pass the signal on to the envelope detector to go on to the lm3914's you said that the gain of 5 would translate to 2.25v, I'm not seeing something!
maybe between the preamp and the filter is where you said that the amplifier would go is the ohhhh ok I think I get it there is 0.45v from the pre-amp and you amplify it to 2.25v yes? so the voltage peak to peak is 0.9v, is 0.45 from 0 to one of the peaks?
I think I might have that wrong this is the picture that I'm supposed to be seeing, ok so the peak to peak of the light blue is approximatly 0.9 and the vpk is the 0.45 its becoming clearer now1702158326038.png
bertus
3,877
It depends a bit on what level is coming from the preamp.
Try to get it in the range of the comercial line level, according the wiki page.
Bertus
Maglatron
Jul 12, 2023
2,025
ok its been a productive day I will be doing research into how to get the commertial line level will this preamp that you supplied a while back will it do the job
Bertus
Maglatron
Jul 12, 2023
2,025
Bertus
commercial as in consumer?
bertus
3,877
Sorry, yes, a consumer level of 0.9 Vpp.
The given schematic can set the gain with the 100k potmeter between 1 and 21 times for the mic.
Bertus
Maglatron
Jul 12, 2023
2,025
Hello
I think I misunderstood the pre-amp needs to amplify the signal to 0.9 vpp and then need an amplifier to amplify to 2.25v vpk (0.45 x 5) why not just use the preamp to make it output the 2.25v vpk
Maglatron
Jul 12, 2023
2,025
what type of capacitors do I use for the buffer, I think for the 100nf the film caps that I have will do but what about the 10uF's? I'm ordering parts!
Maglatron
Jul 12, 2023
2,025
So heres the first filter but I don't think its working properly, I think I have to amplify the signal first! at the moment it flat lines at 6v so part of it works properly!1702207054087.png
  • compiling.asc
Maglatron
Jul 12, 2023
2,025
so that didn't work but the pre-amp works perfectly!! so that is progress!! the filter just stays at a flatline at 6v the filter is for 45Hz and it's a 45Hz signal so it should pass by rights1702209066380.png1702208972465.png1702208712891.png
  • compiling.asc
bertus
3,877
Remove the shorts accross R3, R8 and R11
Bertus
Maglatron
Jul 12, 2023
2,025
I missed something the preamp power supply was not connected to the top rail so I fixed that, it's a better result spread more evenly! still not outputting on the filters though, should I amplifiy it less and use thee amplifier circuit, I'm going to try that1702209741495.png
Maglatron
Jul 12, 2023
2,025
Top Man!! perfect!! so can I use the pre-amp as the main amp or would it be best the way you originally suggested with pre-amp and then amp and then filter??1702210734342.png
Bertus
