Nevermind mate, I've got two meters and they are giving me different results so not sure whats going on, when I use the clamp meter and put it around the positive lead of the battery on the positive wire, it reads 3.4Amps and when I put the clamp around the negative it reads 1.37Amps so something is up and my other meter isn't a clamp meter, so can't measure the current because there is nowhere to put the probes in line, using this one, the out put when I put the probes positive to positive negative to negative the voltage reads -50volt and current -0.43Amps, and then when put the probes positive to negative and second probe negative to positive the voltage reads +50volts and the amps are 0.82Amps with the clamp meter p - p, n - n the voltage reads -50volts and the amps -0.43Amps, and then if p - n, n - p the amps read +1.15Amps BUT the amps should read the same number regardless and just have opposite signs! so I have invested in a better meter! to see whats going on!Sorry, you've completely lost me. Changing V2 to a negative voltage (is that what you want?) would prevent the circuit working.
I found that out when trying to simulate in spice!!Sorry, you've completely lost me. Changing V2 to a negative voltage (is that what you want?) would prevent the circuit working.
Hi there bertus, do you know the order that I should turn on the arduino signal generator to the IR2110 Hbridge, turn on the power to the Hbridge, and the 55v to be inverted to ac? thanksHello,
As far as I can see you already have a H-bridge.
H-bridge - Wikipedia
en.wikipedia.org
Bertus
ok cool thanks for that! so do you know which order you turn on the circuit, then the arduino signals, then the 55v to be inverted? thanksHello,
With M2 and M3 activated will be one direction of the current.
With M1 and M4 activated will be the other direction of the current.
Bertus
forum.arduino.cc
found it!!!Hello,
Does this page help?
And a more extended explanation here:Arduino-Controlled IR2110-Based High-Voltage H-Bridge Motor Control: Lab Guide
A comprehensive community college electronics lab guide exploring how to build and operate a high-voltage DC motor H-bridge using IR2110 half-bridge drivers and an Arduino microcontroller.www.bristolwatch.com
Tahmid's H Bridge - Does it work?
Hi, In the following days i'm planning to build an H bridge to help a friend that needs to control speed on a DC motor of 12V and around 6A nominal. I have been searching information on the past weeks on how these bridges operate with mosfets and IGBT's, but I want to ask for an expert if this...forum.arduino.cc
Bertus
I edited the circuit with the alterations suggested which is better in your opinion?And a more extended explanation here:
