I want to know all of the maths concerning this scissor mechanism!
Maglatron
Jul 12, 2023
2,025
short answer, no, nice browser though and I'm glad you tried to help me out!
Maglatron
Jul 12, 2023
2,025
this might sound stupid but if the forces are in equilibrium (downwards force 2.7N and upward force from the edge of the cam 2.7N) how/why will the scissor/cam mechanism move the weight upwards at the pivot? can someone explain please, thanks
so I had a look around and found that I do need an out of balance force
the 3.05N as I said before will accelerate the block upward at 1.26m/sec^2 so to rise 1.26m It would take a second!
now all I need to know is how to relate the wheel of 10.8kgm^2 inerta to the cam and then to the weight through the scissor
Alec_t
Jul 7, 2015
3,821
if the forces are in equilibreum (downwars force 2.7N and upward force from the edge of the cam 2.7N) how/why will the scissor/cam mechanism move the weight upwards?
It won't. As I said originally, "If the platform is stationary and there are no horizontal forces acting on the mechanism, then the vertical upward force at each of those pivots must equal the weight of the (loaded) platform.".
The applied upwards force must exceed the downward load if you want the load to move up.
Maglatron
Jul 12, 2023
2,025
so the NET Force need to be 3.05Newton that's because the cam will deccelerate the flywheel over the time it takes to lift the weight
bertus
3,869
Hello,
Wich DNS is set in Brave?
You can change the DNS to OpenDNS using the following steps:
Goto Settings , then Brave Shield & privacy , then Use secure DNS.
Tick the Choose other provider and press the triange and choose OpenDNS.
Bertus
Maglatron
Jul 12, 2023
2,025
so the torque into the cam is positive but the same torque is negative from the flywheel and negative torque/inertia of the flywheel gives decceleration I need to find the torque required to give a force of 3.05N at the top of the snail/drop of cam and this torque will be efficient enough because it's the max radius of the cam! so the flywheel is turning 3.3873422rad/sec and its inertia is 10.8kgm^2 how do you work out, from the desired torque at the cam to produce a force of 3.05N radially (upwards) I need a force to relay back to the flywheel to work out it's acceleration or rather decceleration the faster I can do this action the less velocity the flywheel will lose! thanks could even incorporate gears and have the radius of the gear to be 0.01 on the flywheel and add a compound to make the cam turn faster1716662795703.png
bertus
3,869
Hello,
Ok. Go to Privacy and security, then security.
In Advanced, you can select the DNS.
Bertus
Maglatron
Jul 12, 2023
2,025
1716663197367.pngI think the time setting is fudging it the clock wont set!!
Maglatron
Jul 12, 2023
2,025
thanks bertus but it's not having it, so, back to the subject matter the cam/scissor/flywheel torque, torque needed to get 3.05N out of the cam at the furthest from the axis please
Maglatron
Jul 12, 2023
2,025
but its the same across firefox opera explorer and brave and chrome
Maglatron
Jul 12, 2023
2,025
I'm not an expert but it's something to do with the certificates and actual time1716665060066.png
bertus
3,869
Hello,
You can always set the time manualy.
Bertus
Maglatron
Jul 12, 2023
2,025
tried it, believe it or not I've been getting this error on certain sites since I've had my connexion kinda just gotten used to it although you given me a few more options to explore I think I've spent enough time trying to fix it and geting on with it regardless but again thank you for the time and effort. If you have any info on the cam normal to force of 3.05Newtons (what torque I'd need) I'd be well happy
