I want to know all of the maths concerning this scissor mechanism!
Maglatron
Jul 12, 2023
2,025
so I'm reposting for the purpose that the question doesn't get lost in the thread
I have a question if the force was worked out to be 3.05 newtons to lift the weight up in 1 second but the rotation of the cam took 0.25sec with a torque of 0.053Nm will that still lift the weight? thanks and whats gaslighting I need to lift the weight in 0.25 seconds does this affect the torque or can I use the 0.053Nm still I want the cam to rotate at 8pi rad/s thanks
Delta Prime
Jul 29, 2020
2,996
All right;that's enough. I'm only going to respond when I have something to contribute regarding your query, You're a good sport.:)
Alec_t
Jul 7, 2015
3,821
Yes. To lift move anything a distance s in time t involves an acceleration a given by a = 2s/t^2. That requires a force ma, where m is the mass of the thing.
{Edited}
Maglatron
Jul 12, 2023
2,025
ok cool could you help me modify the torque required to lif the weight up in 0.25sec is that (2 * 1.1256637061)/(0.25^2) = a = 40.21238595m/s^2 * mass 0.2753233775kg = force of 11.07140992N 11.07140992 * slope 0.137 = 1.516783159N * max radius of cam 0.1256637061m = torque of 0.1906045931Nm
correct so far?
Alec_t
Jul 7, 2015
3,821
Your value for a is wrong. The force also has to overcome gravity (I've edited post #108).
Maglatron
Jul 12, 2023
2,025
whoops I redid the equation sum and the calculator says 36.0212386m/s^2 for a and the mass is 0.2753233775kg giving a force of 9.917489072N, is that correct now, thanks so did it again to make certain and I got 40.21238595m/s^2 again I'm certain this acceleration is correct!
Maglatron
Jul 12, 2023
2,025
sorry to be naive and probably will recognize when I see it
how do you overcome gravity formula plaease, thanks
wait a sec 40.21238595m/s^2 is correct chat gpt gave the same equation for acceleration a and also gave 40.21238595m/s^2
but you mean that the value for a is wrong because I have not accounted for gravity please need a nudge
wait I know this you just plus on the 2.7N!!!
so 40.21238595m/s^2 * 0.2753233775kg =11.07140992N + 2.7N = 13.77140992N
which corrolates with chatGPT!
Maglatron
Jul 12, 2023
2,025
13.77140992 * 0.137 = 1.886683159N * max radius of cam 0.126 =0.237722078Nm
correct??
Maglatron
Jul 12, 2023
2,025
so then what should a be? thanks I've cross checked that calculation 2s/t^2 and get 40.21238595m/s^2 for a every time!
okay if I add 40.21238595m/s^2 + 9.80665m/s^2 = 50.01903595m/s^2
or do I subtract 40.21238595m/s^2 - 9.80665m/s^2 = 30.40573595^2 because the gravity is in the opposite direction to the upwards motion
is that correct
Maglatron
Jul 12, 2023
2,025
The total acceleration required to move the block of 0.2753233775 kg upwards 1.256637061 meters in 0.25 seconds, overcoming gravity, is... what?? thanks
I think 50.01903595m/^2
Alec_t
Jul 7, 2015
3,821
Agreed.
It's made the same error.
I suspect that, in the absence of anything similar in its training database, ChatGPT may have simply regurgitated the text you posted !
Yes.
Btw, your calculations assume you are lifting the load 1.26m, but the cam will only move the load by (Rmax-Rmin) * number of scissor stages, i.e (.126m-.05m) * number of stages.
Maglatron
Jul 12, 2023
2,025
I can't get my calculator to say 36.0212386 again
Yes.
Btw, your calculations assume you are lifting the load 0.126m, but the cam will only move the load by Rmax-Rmin, i.e .126m-.05m.
I see so the cam need to account for the 0.05m so it's 0.05 + 0.126 = outer radius needs to be 0.176
Maglatron
Jul 12, 2023
2,025
so how to get the calculator to say 36.0212386m/s^2 it's really bugging me! and do you plus on to this the 9.80665?? thanks
Alec_t
Jul 7, 2015
3,821
t^2 = 0.25^2 = 0.0625.
2*s = 2*1.126 = 2.252.
2.252/0.0625 = 36.032.
If your calculator says otherwise, treat it to a new battery or bin it :).
How did you get the 9.80665 figure?
