I want to know all of the maths concerning this scissor mechanism!
Alec_t
Jul 7, 2015
3,821
torque needed to get 3.05N out of the cam at the furthest from the axis please
That's where the maths starts getting tricky. Think of the cam-follower climbing a slope presented by the cam spiral. The precise shape and length of the spiral will affect the relation between torque and vertical force at any rotational angle of the cam. The formula for the length of the spiral is not trivial (according to ChatGPT). Additionally there will be friction between cam and cam-follower.
As an approximation you could consider the spiral has an average radius Ravg half way between the minimum and maximum radii Rmin, Rmax. The spiral length would then be 2 x pi x Ravg. Over that length the cam-follower moves a vertical distance Rmax - Rmin. So, the average slope is (Rmax-Rmin)/(2 x pi x Ravg). The rotational force needed, ignoring friction, would be 3.05N x slope acting at a radius of Ravg, which is a torque of 3.05 x slope x Ravg Nm.
Maglatron
Jul 12, 2023
2,025
just for my understanding can you eplain wih arbitrary numbers, or even the numbers im working with Rmin=0.05m Rmax=0.126m also if it was designed for using Rmax instead of ravg then that would over compensate and therefore be enough if that makes any sense, thanks
I think this is a question calculus was invented for
Maglatron
Jul 12, 2023
2,025
I have a snail shell drop cam who's larger radius is 0.126m and minimum radius 0.05m I want it to rotate and push up on a follower with 3.05Newtons the cam turns through angle 2pi rad before resetting I need to know the torque I need to produce this motion in 0.25seconds
Step 1: Calculate the Angular Velocity​
calculate angular velocity
Given that the cam completes one full rotation (2π radians) in 0.25 seconds, we can calculate the angular velocity (ω) as follows:
ω= dtheta/dt 2pi rad/0.25seconds= 8pi rad/sec
Step 2: Determine the Force Exerted by the Cam​
The force exerted by the cam on the follower is given as 3.05 Newtons.
Step 3: Average Radius of the Cam​
radius Ravg=(Rmax+Rmin)/2=0.088m
Step 4: Calculate the Torque​
Torque (τ) is the product of the force (F) and the radius (r) at which the force is applied:
3.05 * 0.088 = 0.2684Nm of torque
Summary​
The torque needed to rotate the cam and push up on the follower with a force of 3.05 Newtons, completing a full rotation in 0.25 seconds, is 0.2684 Nm0.2684Nm
and using calculus brings the exact same number!! so it seems this approach is sufficient!
Alec_t
Jul 7, 2015
3,821
... because you are not taking the slope factor into account.
Unless you know the cam profile (i.e what is the relationship between radius and rotation angle) and allow for friction you can't expect an accurate answer for the torque.
Maglatron
Jul 12, 2023
2,025
ok how do you do that, could you do the calculation so I can see where I went wrong please? can you clarify that the answer is 0.0369Nm
so I used the chatgpt and entered the variables and it confirms the torque of 0.03696Nm
Alec_t
Jul 7, 2015
3,821
Average slope = (0.126-0.05)/(2 x 3.14 x 0.088) = 0.137.
Since this mythical frictionless slope is linear and constant, the horizontal force to move the cam-follower up it will be constant (the same at Rmin and Rmax) at ~ 3.05N x 0.137 = 0.42N. So the torque at Rmax would be ~ 0.42 N x 0.126 m = ~ 0.053 Nm.
This calculation is for a quasi-static situation; not for accelerating the load at a particular value.
Maglatron
Jul 12, 2023
2,025
from what you said Ravg halfway between 0.126 and 0.05 = 0.088
spiral length = 2pi * 0.088
average slope = (0.126 - 0.05)/(2pi * 0.088) = 0.13745
= 3.05 * 0.13745 * 0.088 = 0.0369Nm
a little confused!
Maglatron
Jul 12, 2023
2,025
so I think I know what you're saying the torque at the tip of the cam before it drops needs a slight increase in torque and if I made that the torque on the input then it would be sufficient to turn through the entire angle 2pi rad
Maglatron
Jul 12, 2023
2,025
so I want to relate the speed of the wheel which is 3.3873422 rad/sec to that of the cam, I want the cam to rotate once in 0.25 seconds which is 8 rad/sec if the gear on the flywheel is 0.01m then velocity equals 0.033873422m/s tangientially add compound gear so that the smaller is meshed with the gear on the wheel and make the larger on the compound drive the cam perhaps through another gear, now we have the correct angular velocity for the cam we then work out the force back to the wheel through the gear system and then the new torque and therefore work out decceleration rough guide
Maglatron
Jul 12, 2023
2,025
so I've found that if the speed of the input gear is 3.3874322rad/sec and the output speed is 8pi and the output torque is 0.053Nm then the input torque is 0.3932Nm and the Gr is 1 : 7.4196 now I need to design a compound gear
-0.3932Nm/10.8(the inertia)= negative acceleration (-0.03640740741/sec^2) this is alpha
the equation ω2 = ω1+ alpha * t
ω1 equal to 3.3873422rad/sec
time = 0.25sec
what is ω2 of the flywheel
okay alpha * t = -0.009101852852
3.3873422+-0.009101851852 should equal ω2 and I get3.378340348rad/sec
this is really good !!!
because on the last drop of the weight initial velocity was 3.293291461rad/sec and it accelerated to 3.3873422rad/sec in 1.881014774sec
now it lifts the wheight to the top height of 1.26m in 0.25sec and only looses 0.009101851852rad/sec the inital RKE was 61.96007076Joules
and the new RKE is 61.62754238Joules difference of 0.3325283762Joules and seeing as the block at full height is mgh
(0.2753233775kg *m9.80665m/sec^2 * 1.26m) the stored potential was 3.392920066Joules
now its a matter of using the gear ratio and making a suitalbe compound gear and design the cam and scissor but proof of concept has been finalised (in my head anyway)
Maglatron
Jul 12, 2023
2,025
now need to add in losses for realism
Maglatron
Jul 12, 2023
2,025
started the working from the beggining theres a couple of little creases to iron out but it's going well I'm going to put together a PDF file explaining from beggining to end, thanks
Maglatron
Jul 12, 2023
2,025
That’s the best comment you’ve made since you started.
Your math has drifted into pico and micro. Why?.
Tools to measure this costs millions of pounds. Just my 2 cents.
It looks like you're looking at the size of the number and not following the math of how they were derived or what they mean and stand for! thanks
Maglatron
Jul 12, 2023
2,025
I have a question if the force was worked out to be 3.05 newtons to lift the weight up in 1 second but the rotation of the cam took 0.25sec with a torque of 0.053Nm will that still lift the weight? thanks and whats gaslighting I need to lift the weight in 0.25 seconds does this affect the torque or can I use the 0.053Nm still I want the cam to rotate at 8pi rad/s thanks
Delta Prime
Jul 29, 2020
2,996
You must have been born on a highway because that's where most accidents happen!
That's gaslighting.
Your question is gibberish because you're not following the math and do not know how it's derived. I am smarter than you.
That's gaslighting.
And I will make condescending remarks as to why you're even on this site.
That's gaslighting. That's being a bad boy.
Maglatron
Jul 12, 2023
2,025
ok that was NOT my intention the numbers are small because when you multiply numbers over 1 by numbers under 1 the resulting numbers get smaller and when you divide small numbers by large numbers the numbers get smaller and when you multiply numbers under 1 the numbers get even smaller I don't know what else to say wouldn't be too bothered by that to be fair
