Delta Prime
- Jul 29, 2020
- 2,987
- Joined
- Jul 29, 2020
- Messages
- 2,987
That's good! That was a psyc- teststill don't know what the scissor has to do with windmills
Gotcha." Wonga " had to look that one up.quid skrillar moola wonga p's coinage doe paper etc
If you do happen to have any other questions fire away, I'm ready!Yes.
I think you're confusing yourself and us by using too many decimal places and not enough punctuation in your posts.what do you guys think
so whatever I do, the energy to move the 10.8km^2 inertia flywheel at 0.05rad/s^2, that weights approx 40kg - in the ring format, the energy is 3.3929J. But if I have (1 newton then that weighs approx 102grams) then J/N = 3.3929J / 1N =meter (in this case the distance moves up, high) then the height it needs to lift up is 3.3929m, and the lever arm is r, and s = r theta 3.3929/0.34906 equals 9.72m = lever arm, the flywheel moves at 2pi rad/s initially, the wheel is about 392 times the mass, and it's moving. I think the problem is starting me in the face, but common sence says that I should be able to use the mass of the moving wheel to shoot the 102gram wheight up easily
if the force downawrd is 0.25N (25gram 0.02549kg), it needs to lift 13.5716 meters, upward. It just makes sence that the moving mass of 40kg 10.8kgm^2; can lift the 25 gram weight 13.5716m easily - given the right mechanism, what do you guys think? if it hits with impact to "shoot" it up - and not lose 3.3929J in doing it, I think it's about power which is J/sec, so if I move it up slower than it falls eg 1 sec to fall equals 3.39292watts, but if it lifts up in 2 seconds then it will use 1.6946watts to lift
now I'm going the other way heavier weight, less height, so less stage of scissor and for a cam profile of 5% slope!!weather the distance of the arc of the lever is lifted 1.3194m and 2.5714N downwards, or arc of 13.5716m and 0.25N, the energy is = to 3.3929J for acceleration of 0.05rad/s^2 and inertia of 10.8kgm^2
need to design a cam that varies over it's slope 10cm and must be 5% any ideas people, 1 lobe! max radius min radius or a formula - must tick 5% slope box and 10cm from max to min box?? ideas, thanks does not need to be 10 cm the important part is it needs to be 5% slope, thanks but would be good if the solution ticked both boxes for the design of the camFrom energy considerations, for a n-stage scissor mechanism the vertical force Fv the cam needs to provide will be n x the vertical force fv needed to accelerate the load at the top. But if the cam has a s% slope then the horizontal force Fh on the cam follower will be s% of Fv,
If n=10 and s=10% (which I think is the arrangement you presently have) then Fh will just happen to equal the force f.
It is Fh which determines the cam torque needed.
can I rearrange this formula for 5% slope??slope = Rmax - Rmin / 2pi * Ravg
Obviously you can't, why else would you askcan I rearrange this formula for 5% slope??
makes for Ravg = 1/2 × (Rmax+Rmin).average radius Ravg half way between the minimum and maximum radii Rmin, Rmax.
