I want to know all of the maths concerning this scissor mechanism!
Alec_t
Jul 7, 2015
3,821
do I need to unlock boxes to see the formula?
No. Just click on a Value cell (e.g. D14) and its formula shows in the Formula bar above the column headings.
If you need to edit a formula directly then you have to remove the cell protection.
Maglatron
Jul 12, 2023
2,025
okay thats cool so how do you do anything special to make a formula box doesn't it go flashing or something I remember you press = and it goes flashing
I now REALLY appreciate what you done, damn that is alot work but I think I get it now thanks I don't even know where to start with the one I provided
and by the way this was never supposed to be a chore I'm going to put some time into that spreadsheet I'm sure I can do it too
Maglatron
Jul 12, 2023
2,025
okey dokey thanks
okay there is far too much info there is there anything that I should look up inparticular
I'm doing a beginners course on the tube
Alec_t
Jul 7, 2015
3,821
That should help.
Btw, you realise that if lever 2 has a fixed length then the weight will fall in an arc, not vertically? Alternatively if you want the weight to rise and fall vertically (which the maths to date has assumed) then either lever 2 length has to vary or else the flywheel and gearing will have to move horizontally.
Either way, the torque exerted on lever 2 by the falling weight is not constant, so neither will be the forces or torques acting on the gears as your spreadsheet apparently assumes.
Maglatron
Jul 12, 2023
2,025
yeah thought of that too crude drawing but simple enough to implement this way the effective lever arm stays the same and so constant torque! the bar is allowed to slip through the jig hope you get the idea
ingenious right :)
Alec_t
Jul 7, 2015
3,821
The radius (the effective lever length) with that arrangement isn't constant, but fortunately as the weight falls its resolved component at right angles to the lever (which is what produces the torque) varies to compensate, so torque is constant.
Maglatron
Jul 12, 2023
2,025
yes I know!! its about effective lever arm (not radius you're correct) and the vector component of the force acting perpendicular to the axis of rotation therefore as I said the torque is constant in this configuration but you explained it well, so are we on the same page?
Maglatron
Jul 12, 2023
2,025
so spreadsheets are really cool I will now be using it for various tasks in the future, thanks
Delta Prime
Jul 29, 2020
2,996
Okie dokie Don Quixote... Scissor lifts are starting to look a lot like windmills....
Maglatron
Jul 12, 2023
2,025
hey up Delta Prime matey looked up quixote he's a cool author for his books to still be read, although I don't see the connexion between the scissor and windmill, but it's food for thought!
Maglatron
Jul 12, 2023
2,025
I bought a Udemy course to better understand the speadsheet maker (openoffice calc) 12 quid 7.5 hours of video bargain I'd say
Delta Prime
Jul 29, 2020
2,996
Do your 12 squid have to be alive or dead for payment, I never heard of that.
Okie dokie,Don Quixote; rhymes!
That's the only reason why I said it, I should have been a gangster rapper.
But I don't know Ebonics.
Maglatron
Jul 12, 2023
2,025
quid means pound sterling I think the man explaining in the spreadsheet series of video is one of those that uses and is fluent in ebonics !
Delta Prime
Jul 29, 2020
2,996
Your just trying to make me jealous,..
& it worked,
But I still have to believe that you guys do not carry around pounds of Sterling silver with you, I don't think they make pant pockets that big or strong enough.
Maglatron
Jul 12, 2023
2,025
I think you mean trouser pockets
still don't know what the scissor has to do with windmills
